BobDiaz
The Professor
I was going through the numbers for recording time at 100Mb/second and found something that does not add up right.
If we are recording at 1080@60i and take the number of bytes per second required, times 8 to convert to bits, and divided by the compression ratio plus the uncompressed audio, the number 100Mb/second is very close to what I get. No surprise there.
Working the other way, 8GB = 8 minutes of video at the maximum data rate (100Mb/second), the answer comes out weird. A GB is equal to 1,024 MB, but for this calculation I will use the lower number of 1,000.
1,000MB (1 minute of video & audio) x 8 (8 bits = 1 Byte) / 60 (seconds in a minute) = 133.333...Mb/minute!
Now I know that there must be some overhead, BUT according to my calculations: An 8GB P2 Card has 6GB of video/audio and 2Gb of overhead. That seems WAY TOO MUCH! :shocked: That's 1 byte of overhead for 3 bytes of data.
(1) The camera records at a higher data rate than 100Mb/second OR (2) The P2 cards hold more than the 4GB=4 minutes, 8GB=8 minutes times.
This is a request for anyone with an HVX-200: Start with an empty card and record until the camera says out of memory.
How long is the clip you recorded?
What files were created and how big is each file?
Even with a short clip, it would be interesting to know the running time of the clip and how big it is. My PC can't play the native files, so I'll need someone else to look it up.
Bob Diaz
Bob Diaz
