P2 "R-Series"
My friend just got his HVX-200, and it came with a 16 GB P2 Card. It says "R-Series" on it, and my old 8GB doesn't. What does this mean?
Also, when I delete clips, it takes almost a second per clip to delete. His takes about a quarter of the time. Is that because of the R-series thing? Or is it because his is new? Or is it the firmware update?
Thanks,
Ben Tubb
Hello Ben,
R-Series is simply the manufacturing method that Panasonic switched to with the newer cards. The older cards have actual SD cards placed on the circuit card with sockets. The R-Series is a bit more robust because they got rid of the SD cards and placed the actual memory chips on the circuit board.
Best regards,
Andrew Hoffman
Vice President
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858 (US)
301-790-0103
Fax: 301-790-0173
andrewh@spec-comm.com
www.spec-comm.com
An SD card on a circuit card with sockets... sounds like something a smart company would figure out how to upgrade. Then make a killing on selling it to HVXusers that have obsolete 4GB cards that need an upgrade. Interested anyone?
From what I understand, that won't work because there is a microprocessor that is hardwired for that specific storage amount. So even if you change out the SD cards, you will still be stuck with the same amount of storage.
P2-R Series Incompatibility
I own an AG-HVX 200P, I recently tried to dump some footage for a friend from an "R-Series" P2 Card. The camera would not recognize it prompting me that it was an "Incompatible Card". WhaD up with it?
What is the difference between P2 Card R Serie and A Serie
Please help me :
What is the difference between P2 Card R Serie and A Serie ? Which one is older ?
And about H Serie?
Thank you
Cooki
First was H, then R, now A. A is the current 'standard' P2 card version. For all intents and purposes, they are the same thing. The prices dropped with each new release. If you buy a new 'standard' card today it will be an A, if you buy a used card it could be any of the three.
'E' Series cards are different. They use a different kind of flash memory. It is cheaper and so the E cards are less than 1/2 the price of the A cards. However, it is also limited on how many times it can be rewritten. If you used it every day it should last for 5 years, most cards do not receive this kind of use, and should last you much longer.
Best,
Jasmine Moore
Administrative Assistant
Specialized Communications / Noventri
800-359-1858 (US)
301-790-0103
Fax: 301-790-0173
jasminem@spec-comm.com
www.spec-comm.com
www.noventri.com
H & R appear to be basically the same, but A does have the advantage of being faster than the older cards were. The older ones were 640mbps maximum transfer rate, the A series are 800mbps.
I have an 16 GB R series and want to upgrade to 64 GB. B&H sells the 64 GB E series.... is this the latest greatest card?
Will both cards work.... after software upgrades? I purchased my HVX200 before the E series cards came out.
