Philip Bast
When I first bought my HVX200 I continued to shoot to SD tape then upgraded to P2 cards about a year ago. I have a pair of 64 Gig cards (Black with 800 transfer rate) which I rarely take out of the camera. I offload straight to Final Cut via 1394 cable and do not own a P2 reader. In essence, it's the same process I had always used with tape, going back to DVX100 days.
When I first moved to P2 cards, I was tickled to discover faster upload times. Whereas tape transferred in real time, the P2 transfer seemed to take half the time. I don't have specific transfer time notes from a year ago to document this, but that's my recollection.
In the past several months however, transfer rate seems slower ... almost as slow as the old real time transfer from tape.
For example, last night I shot a stage performance in two acts, so I had two clips to upload. I noted the time of transfer start and stop. Act One, 82 minutes, took 73 to upload. Act Two, 86 minutes, took 77 to upload.
So, I have several questions:
1) What is the actual transfer time from P2 to Final Cut supposed be, using 1394 cable?
2) Is there a tendency for that slow down after extended use?
3) Do P2 cards get cluttered and need to be "de-fragged" despite being constantly reformatted?
4) Do I need to swap cards from slot to slot each time I reformat?
5) If so, is there a way to specify that in format settings, rather than physically swapping slots?
Not sure whether it makes any difference, but I always shoot 720/24PN for maximum data storage, allowing me up to 342 minutes continuous shooting without offloading. Speed of transfer isn't normally an issue, but during summer months I will be shooting some day-long events and need to offload fast during a supper break, in order to free up space for 3 or 4 hours shooting in the evening.
Also, just to confirm: apparently the camera doesn't sense space recently used on the P2 card once it's erased. I just checked. There were two minutes remaining on Card 1 from last night's shoot. I erased, then let the camera run 5 minutes. It chose Card 1 as expected, but did not move to Card 2 after 2 minutes; all 5 minutes are on Card 1. That tells me the camera is not choosing to spread data storage equally throughout both cards.
Any thoughts on this appreciated.
