What is the advantage of P2 workflow? I will try to compare it with a tape DVCPROHD deck or HDCAM or DV or whatever.
First the data on P2, HVX users please correct me if I get something wrong:
4gb cards store about 5minutes of 1080p if they are 4000gb and the format is 100mbits/sec.
A P2 store, the official Panasonic solution is advertised to have a speed of 4minutes for a 4gb P2 card with verify off. I guess that would be double the time for verify on.
I have to transfer the cards to P2 store while I'm shooting. I have to get someone to do that or stop shooting to initiate the procedure and switch cards while I'm shooting.
I can't monitor the footage for errors while I'm transfering so I have to do it later. But I can use verify and have slower transfers.
The transfer speed to Laptop varies from 4 to 3 minutes for 4gb card which is 5 minutes of footage without verify.
I have to disrupt my work to change cards every few minutes and always make sure there is a second card inside in case the first gets full.
If the producer wants the material I have to either take extra time to transfer the material to another hard disk at close to real time (2.5inch disks) or give him an expensive P2 store or laptop.
Later, I have to watch the footage for the first time in real time since this is something I need anyway. This is real time for me. Some might disagree.
I have no backup of the footage I'm watching. I need to make a backup of what's on P2 or transfer the P2 drive to a computer before editing in order to work on a backup. Some might disagree on this, but bad things happen. The backup procedure takes time. I imagine it takes the same with a P2 transfer since it uses a 2.5inch disk. Close to real time.
Time required: If everything works perfectly and I don't run out of space, I will have to watch the material in real time later. If I need a backup I also take the time to do one. This is close to real time again.
The data on tape.
I shoot whatever I want without thinking about tape for one hour of footage. If tape ends I put another tape in and drop the old one to my pocked.
If the producer needs the tapes I simply give them to him.
Later I transfer the tape to PC while watching it for the first time to get familiar with the material and make sure it is ok.
I have a backup on tape since the footage I will edit is only a copy.
Why would I prefer P2 workflow over tape workflow? It certainly takes a lot of extra time and makes me have to think about more things. I have to think more while shooting and do card changing/transfers. I have to think about how I will backup and where (with the added cost in time and materials for the actual backup). And I still have to watch the footage. With tape I would reach the same results while simply watching/transfering the footage.
The data on tape.
