jpsheets
Hi all,
I posted this in the technical section with no luck. Here's my problem -
Tried to import some test P2 footage into my Apple G5 using the camera as a firewire device. I'm following the steps in the Apple white paper. Problem: when I try to copy the clips into a folder on my desktop, I get the following message:
"The operation cannot be completed because the item "lastclip.txt" is locked"
There's probably a real simple answer for this but I couldn't find any similar problems using the forum search. Any help you guys can give is appreciated.
thanks in advance!
thanks in advance!
