Got my HVX on Tuesday and finally had a chance to shoot on Saturday. Filming was great and I couldn't have been more pleased with the HVX's performance in the field. Except when my 4GB card ran out, but other than that, things went swimmingly. Got some great shots and was really lookikng forward to seeing them on a big screen at home. Today I finally got to work on developing my post production work flow, and, well, it's not a good start so far. I get home to offload the P2 and import into FCP. (5.1.1 on a dual 2.7 G5 running 10.4.6. Anything in Parenthesis is there for troubleshooting clarification) I set the HVX up into PC Mode. The P2 card mounted and I started copying everything over to the computer (Folder over on My G-raid) About 36 mb into the transfer everything froze. The transfer just stopped and wouldn't progress for about 10 minutes. I tried ejecting the card from the finder, but no go. I tried relaunching and the Finder became semi frozen (Dock would work fine and I could launch programs, but all icons on the desktop itself were gone and there was no way to explore files and folders a.k.a. apple N didn't do s#!t.) After trying several tricks to get the Finder to fully relaunch, nothing was happening. I had to restart the HVX. As soon as the HVX was powered off, the finder sprung back to life with the nerve racking "Device Improperly Ejected", or whatever it is when you unplug a device (P2 card in this case). I fired the hvx back up and decided to go the laptop route. So I pop the P2 into my Power Book. The card showed up fine and I pulled everything off and started importing into FCP. The attatched picture is what everyclip looked like. Just in case it was a transfer issue, I tried every other way possible to get files off the card. (Pulling files off the card from FCP while the HVX was in PC Mode on both systems. Pulling files off the card and copying them to a folder on the computer on both systems, and using the PC slot to copy via the Finder or Ingest through FCP)
Everything showed up the same.
Just in case, I reformatted and shot some random footage. Same thing.
The original footage was a mix of 720 and 1080. Both 24p. I had the same problem on both, so I know it wasn't just FCPs lack of 1080p support.
I'm hoping this is an FCP problem and not something born out of having to restart the HVX while the card was still mounted on my frozen system.
Thanks for any help, advice.
This forum rocks and I've spent way to much time here even before I bought my HVX. Thanks to you guys I've been able to out geek several of the guys at work.
If this has already been covered just hook me up with a link as I couldn't find anything on it.
Thanks all.
Thanks all.
