digitalisland
I have been using the workflow suggested here.
Shoot on location, place P2 Card in Mac Laptop, use disk utility to make a disk image (read only, no compression). Back-up DMG file to external hard drive.
After two days of shooting and 7 P2 transfers one reel will not import into FCP.
This is the first time this has happened and I am going crazy. I have tried everything.
I have tried to import direct (first clip is fine then get nothing but static in the preview window and the rest of the files will not import)
Tried moving the files back to the P2 card and using the Camera function "fix clip" but it is "unable to fix clip".
Ran disk utility on the disk image - found several errors. Converted the DMG file to read/write and ran disk utility (after fixing the errors, was still not able to bring in footage).
Can pull some of the MFX files off of the Disk image. Is there a way to convert the MFX to Quicktime?
I don't know what to do as I need this footage (will be almost impossible to recreate).
Also, makes me very nervous going forward. What caused this and how do I avoid this in the future?
I have two laptops - a new macbook pro (last model before intel switch) and an older powerbook (550 mhz) with a brand new fast (7200 RPM) HD. The corrupt disk image is from the older powerbook...could this be an issue? I saved the disk image to the internal HD before backing up to external HD. Also, is there an issue with the PCIMCA slot?
Just trying to figure it all out.
