P2 continuously recording
Serge,
If it's on a tripod I'd say yes, but handheld and I'd say no. Unless you have an assistant doing the exchange. I'm pretty much going to have to bring an assistant. I also realize that you may need 3 cards to shoot continuously without being completely under the gun. If it takes 6 minutes to back up 10 minutes of footage.. it will require some media management.
Justyn said:
Serge,
Yes, it is on tripod and let say I want to record "hours". To be able to shoot continuously I need at least 3 cards but I'm afraid when I push the eject button I gonna shake the camcorder.
You know what would help ... a enxtension cable for P2 cards .. so you'd jsut have a couple of cables comgin out the back fo the HVX, into an external reader. SO you'd be swapping cards without having to touch the camera.
- Mikko
Sounds like a cineporter - 80 Gigs of P2 data
will have longer cables so they can attach anywhere
I doubt even if it's on a tripod you're going to have an easy time switching out cards with absolutely no "shake" whatsoever.
What kind of take are you doing that requires so much length?
If you're on a tripod the entire time and the camera is not moving, a much better solution would be to stream to a laptop directly and get as much running time as you need.
