EDV
Clips with the X won't play or delete. When I tried to delete , it says " Read Only, can't delete clip"
The clips only malfunction after metadata editing, and I did the exact same metadata editing procedure in a different clip on a different folder and the clip plays fine.
NOt sure what is happening, no matter what metadata editing procedure I use, the clips get "corrupted" an "X" appears on them and they can't be played or deleted. Nor can they be restored to what they originally were, even if I erase the folder from the Ingest Folders, and Register it again. If no metadata editing is done on the clips, they play fine, no "X" appears on them. I am thinking the Folder is corrupt, because I've tried 2 other P2 Folders with clips, and they've allowed me to do metadata editing on them. Out of frustration I re-installed P2 Viewer ( the old version ) and the same clips refuse to accept any metadata editing, they show the X as well, can't be deleted, but at least they play.
Not sure if it matters, but the folders giving me trouble, were originally "Virtual P2 Cards" , whereas the newer folders not giving me trouble were simply copied and pasted to the hard drive ( and then registered in P2 Viewer Plus )
