p2 clips failure to import
baremis
Hi,
Today i shot some takes with HVX 200 and copy all cards to my vayo laptop, then copy to my g5 to import with final cut.
when i tried to import final cut gave me a error message.
"One or more p2 clips failure to import. probable incomplete or corrupted files."
how can i fix this problem?
After install P2viewer this problem apperars...
The P2 card has a contents folder and a lastclip.txt
Always make a new folder and copy the contents folder and the lastclip.txt file.
When opening in FCP just navigate to the new folder you made not the contents folder. See if that works.
If you erased the lastclip.txt you can try to convert the files with Raylight on the PC.
www.dvfilm.com
I've had the same problem with my PAL camera.
I attempted to import from the mounted P2 card, and also a copy on my hard drive (I copied the CONTENTS folder and the LASTCLIP.TXT file into their own directory).
The import window displays the thumbnails and timecodes.
I'm using 10.4.5, FCP 5.0.4 and QT 7.0.4
Managed to import clips recorded in 1080i50 amd 1080p50 mode. If you don't set a logging bin, the process will not work - so, don't forget!
Go to the footage forum to see two times 38 frames of pure 1080 DVCPRO HD footage.
The footage is anything but special, but you might have a use for it.
