I just received my 64 GB P2 E series and want to begin recording.
1. The 200HVX manual states that it is important to format the P2 cards with a P2 device. Do I need to purchase yet another piece of equipment? I know I can simply format in the camera. Confusing.
2. Is there some directions on transferring to FC Studio 2? The manual provide directions on transferring to hard disc, it further states that the hard disc drive must be formatted, which will erase all data. Does this mean that if I save my footage to my MacPro, or any other hard drive it has to be completely empty and formatted?
3. Half of my footage for this project was shot on the Fire-Store 100, shot in 720P24. But I noted that the footage was actually delivered to FCP as 59.97 in the timeline. ( This is due to the "over 60" frame rate from NOT using P2.) If I NOW begin to use the P2 will I have problems?
Some posts have indicated that I should not shoot in 24PN but instead use the 24 to avoid problems with different frame rates. And Barry Green suggested that I remove the pulldown on the Fire-store footage to match the new P2 footage but Shane Ross from the FCP users group says this can't be done. Any suggestions?
SHANE ROSS WRITES:
YOu have film like images. You have the 24p look....just in a 60 frame container.
Sorry, there is no way to "remove pulldown" from 60 frame material. That process is designed for removing pulldown from 29.97 footage...it doesn't work with 59.94 footage.
That camera does 23.98...if you shoot 720p 24pN. That option is only available on P2 cards. It also shoots 1080i 24pA...which is 24p in a 29.97 stream with Advance Pulldown..meaning it can be removed when you log and capture. But getting 23.98 while recording to a Firestore...not plausible.
SHANE ROSS WRITES:
