starcentral
Sorry I should have said a warming filter in post or on-camera via filter... because really the results would be the same. But I personally am not a fan of baking in drastic looks in camera. It is just too risky if screwed up - even if you have "experience".
Where colours are mixed, you can try balancing more towards the cool side ie. 4400k to 5000k then use tungsten on faces, CTB everywhere else and when you add the warming filter in-camera or in post it will keep the CTB looking blueish, and keep the tungsten looking warm.
For other shots, it could be as simple as gelling one light yellow and the other blue, as seen in the shot where the man is running between those two large tanks.
I'm really just guessing here, best thing to do is try it. You can also stick warming gels over the lens of your camera for testing purposes and play with your white balance. Sooner or later you will see what kind of look you can really dial in.
I'm also a big fan of using coloured LED lights out of frame to really cheat it. You can get colours like yellow and blue quite easily... or just use white ones and create your own tube from gels to put them inside of. You can tape gels around florescent bulbs.... you can..... . . .
