Output to 2 monitors?
bill totolo
Specifially, I'd like to know if I can run 2 monitors at the same time off my HVX200.
The monitors I have in mind are the Marshall 7" V-R70-HDA and the Panasonic 17" BT-LH1700W.
we did that on Heart of Now. the marshall we had rented also had component out which we sent to the same 17" panny you have.
HVX > Marshall > Panny
hi there, i found this:
"If your Marshall is the same as the one I've got (the VR70HDA) then it has a loop-through for the video. So you can connect your camcorder to the component video in on the marshall, and connect the component video out on the marshall to your second monitor"
http://www.dvinfo.net/conf/showthread.php?t=105378
Also these monitors both have loop thurs for the companant so just use your Componant Leads from your cam to monitor one and loop thru to the 2nd :)
That's the way to go, if you have a loop-through, no problem with the Nebtek NEB70HD too.
I have both of those monitors. Just loop component into the marshall and back out to the panasonic.
Shane.
Hi!, Does anyone have idea, i'd like to know if the BT-LH1700W could show the wave form from RGB inputs YPbPr?, or is it just composite? or SDI only?
Does this scheme also work for Totevision LCD 703?
I don't have second HD monitor. But yesterday, I tested with my friend's SD monitor.
Component out to Totevision (1080i) then output to the SD monitor.
Perhaps, because it was different signal (HD and SD), I didn't see anything from the SD monitor.
Does anyone have a cheap solution for the 2nd monitor without compromising the HD component out to my Totevision?
