Denis Haineault
Hi,
If this should be moved to off-topic, then let it be...I just figured audio guys in the audio section may have better answers.
I just received my audio gear, from a store with a good rep here on DVXUser. The order totals $3.5k. This is my first time ordering this kind of equipment.
Two of the items (AKG SE 300B amp with CK93 capsule) came in their respective boxes. The boxes themselves are in a semi-rough shape -- one of them is torn, enough to make me raise a concerned eye brow. But so far, not a huge deal.
The amp seems in good shape, but I can see what appears to be lead from a pencil in the cavity where the switch is -- i.e. it's been used before. There's a wire that comes with it (don't know what it's called...I'm new'ish to this...an extension?) with a male/female bayonet on the ends of it. There are a few scratches on the metal part of it.
The CK93 doesn't have the little foam cover that's supposed to be with it -- there's a big, glaring empty space in the box where it should be.
The bundled documentation that came with both the amp and capsule looks like they were just thrown in there.
Everything I bought is supposed to be new (everything else appears to be). Should I be concerned with this, and insist that I get the new things I ordered? Or is this one of those "you got something that was on display, and unless it's defective, don't worry about it" kind of thing?
Just wondering what you guys would do if you were me.
