Optimal audio meter level?
Optimal? Peaking just below the red. But most people prefer to aim for a specific AVERAGE level. Some say -12, some say -20, depending on delivery specs, etc.
However, the HMC audio is compressed, and the circuitry a bit noisy... which become apparent when you need to BOOST levels in post. Most of my work is music, not film dialogue... and I always find the best bet is a very good sound check and optimizing levels to "peaking just under the red."
Just remember these two contrasting guides:
1) Quality-wise. it's better to lower levels in post than to raise levels in post - so record as hot as possible
2) Setting levels too hot is catastrophic, setting them too low is more recoverable - so err on the side of too low rather than too high
... and look for the safe ground: set the levels as hot as possible without risk of hitting the red.
Best idea is to record a mono source to both channels, one more ambitious and "hot", while keeping the other one low enough as a safety net in case the hot signal is over driven. In most cases the hotter signal will be just fine and will sound better in post.
Can you comment on what you mean by "noisy" ?
I'm just wondering if you've done any tests to see what the actual noise-floor is for the HMC150.
I don't record music, but I do record dialog via good mics and a Sound Devices mixer feeding the camera. The only noise I've experienced to date has always been the ambient room noise.
