Justyn
Greetings all and I've been meaning to put up these samples for a while and today I finally did that. I've got two examples in this clip... One has some post work in terms of some dissolves and such, and the other is just a camera original. Neither has had any other processing. I've used this on a bunch of shoots and I absolutely love the fisheye with the knowledge that you need to clean it a good while before or after the shoot since the focus is right on the lens and the smudges and such will show up. For 200 bucks it's just as good as the century except that it's not a bayonett mount.. which is both good and bad. It's good in that you can use it on any 72mm camera and bad in that it takes a bit more time to take on and off. I do use this with a filter just because it would be easy to stratch the naked lens....
I'll post other samples when I get around to it.. but it's a great wide angle or fish option and doesn't have the superfish look which is a gimick anyway... This is something that I find myself using quite a lot and I highly recommend it.
cheers and enjoy.. comments and feedback welcome.
http://www.electriccowtheater.com/DECEPTION/OPTEKA .mov
