On Location not showing HD images
jrp
Hi.
I connected my HVX200 to a fresh intall of Adobe On Location. And there's the deal.
When I output 480i video, everyting is ok. But when I change the camera to any o f the 720 or 1080 modes, I get no image on the field monitor's window.
Any help would be apreciated
1.- see that your HVX200 is in a "Non PN" mode
2.- make sure you are not in 1394 "host" mode
3.- Selec the HVX200 in the On location device menu
4.- do not use a firewire Cable Longer Than 15 Feet
this should show the image in your monitor and let you record to your HD.
PS: you better use a external USB (best if Sata) hard disk in your laptop
Jrp I had same problem before I get the answer for that , problem of OL with DVPRO HD that need very high speed laptop that have hard disk in 7200 RPM so when I get this problem I buy new laptop from HP that is made for editing and video graphic so I test a lot of time and work perfect so if you interesting to work with OL in HD mode tray to get this laptop and I warranty you that will be no problem at all .
http://www.bhphotovideo.com/c/product/531617-REG/HP_Hewlett_Packard_RM263UA_ABA_Compaq_8710w_Mobile_Workstation.html
