Max R. Wilson
Stream Master
Has anyone attempted making a on camera LED light?
like the light panel one or vidled one?
It looks pretty simple. I figure i will get a custom battery pack made at batteries Plus thats rechargeable, that runs at 12V. with 48 LEDs it will draw about .4 Amps. and i will also hook a dimer switch to it.
I ordered 100 LED's from ebay and will wire it in a array like this:
Code:
Solution 0: 3 x 16 array uses 48 LEDs exactly
+----|>|----|>|----|>|---/\/\/----+ R = 82 ohms
The wizard says: In solution 0:
each 82 ohm resistor dissipates 51.25 mW
the wizard says the color code for 82 is grey red black
the wizard thinks ¼W resistors are fine for your application
together, all resistors dissipate 820 mW
together, the diodes dissipate 4080 mW
total power dissipated by the array is 4900 mW
the array draws current of 400 mA from the source.
