Good questions. The Oktava has a lot of low end, the Sony?
Oktavas come with a low cut module, maybe that was screwed in before?
I did notice a LOT of handling noise on the sample, maybe it's a boom op problem?
Maybe this last was in a place with some ventilation system problem and the others weren't?
Maybe you had phantom set to 48V before and switched to 12V.
Maybe a neighbor got a hold of some of those French police subsonic crowd control devices and is trying to get even with you for stealing their parking space?
As a rule mics don't create sounds. They pick up sounds around them. Bad wiring can act like an antenna and pick up garbage. Also dirty contacts can act as radio receivers.
I have a fine mic I can't use around Navy Radar, because it "hears" it. Tried all kinds of things but nothing solved it. There is nothing "wrong" with my mic but it's circuit for whatever reason resonated to the Navy radar signal. Airports are not a problem?????
It also picks up the low freq. ground/underwater radio that he Navy uses. You can map the antenna arrays with it like a Geiger counter.
See this tech support bulletin on the Sound Devices web site for a possible explanation of the cause here. http://www.sounddevices.com/notes/mixers/oscillation-xfmr-inputs/
