In another forum, someone advised using the low-cut filter to help filter out handling noise on the boom with and Oktava MK-012. It was mentioned that the lows that are removed from the voice track will not adversely effect the track. In fact, it's common to remove the lows for a better mix.
I'm using this for audio for filming a documentary, so there may or may not be music. Is the consensus that low-cut is the way to go for this usage? Also, does anyone know reputable places to get the low-cut filter?
Thanks, Dan
Thanks, Dan
