Mitch Gross
Below are the changes we are expecting to release in our February 2014 firmware update. Some features may be added or dropped as we approach release, but we have high confidence in this list. Also note that the Popular Compressed Codec is subject to manufacturer's certification.
Please note that this will be a free firmware update. Firmware updates require the use of a Convergent Design Odyssey SSD. All firmware within the Odyssey7Q will be updated, so the new C500 functions will be available to anyone who has already purchased the use of this option and will be available to test in demo mode (bar across recorded image) for all others.
New Features
- "Popular compressed codec" in 422HQ for HD (1920x1080) up to 30p.
This is for direct recording of HD signals. Converted RAW signals will come later (UPDATE: see FS700 notes below).
- Free File Combiner program on our website (for Mac & PC).
The "popular codec" is recorded in Fat32 structure so this simple program will combine lots of little files into one standard file. A simple and quick maintenance operation.
- Adobe compatibility for .DNG files.
Use Odyssey7Q-recorded Cinema DNG files in any Adobe software. This change will have minor alteration of Resolve settings, for which we will also publish new suggested presets.
- Mix file types on SSDs.
Record RAW or video, single SSD or spanned files, without needing to change drives.
- OLED zoom frame drag.
In Pixel Zoom mode, one can use the touchscreen to drag the zoomed window around the frame.
- Histogram reference lines.
Similar to the reference lines in the waveform display.
- 1.33 Frame Guide.
An additional frame guide option, noting 4x3 cutoff within the 16x9 image.
- Screen flip.
When the Odyssey7Q is turned upside down, the image will auto-flip for correct orientation. Can be turned off if desired.
- Audio meters & output level control.
Graphic audio level meters in Upper Tool Bar. Audio Out adjustable level control enabled.
- Clean SDI/HDMI output.
Option to remove image analysis tools from SDI & HDMI outputs.
Known Issues Repairs
- Fixed image tearing and dead lines.
In some shooting modes the display would show the image splitting horizontally during panning motion. Additionally a black line could appear across the frame approximately 1/3 from the top of frame or 1/3 from the bottom. These processing errors were only ever in the OLED display and have been corrected.
- Fixed FS700 RAW white balance.
White balance should now track correctly and accurately.
Canon C500 Recording Option Updates: New Formats Support
- QHD up to 60p
- 2K 12-bit 444 in .DPX up to 60p
- 1080p 12-bit 444 in .DPX up to 60p
- 1080p 10-bit 422 up to 120p
FS700 Recording Option Update:
- 4K RAW to High Quality HD, recorded in 10-bit 422HQ compressed codec
The Odyssey7Q will be able to accept the 4K RAW signal, deBayer it and super-sample it to 1920x1080 with our new advanced high quality algorithm. This algorithm improves both the deBayer as well as the super-sampling processes. The Odyssey7Q will then be able to record the HD signal in a popular compressed codec in 10-bit 4:2:2 at a high quality. At this time we can state that the Odyssey7Q will be able to do this at frame rates up to 30p, and it is expected to attain the camera's full 60p frame rate with further development. Additinal further development will allow HD capture in 12-bit 4:4:4.
(New Update, 2/17/14)
- 4K RAW Recording
The Odyssey7Q will be able to accept and record the full uncompressed 4K RAW signal. This 4096x2160 feed is available from the FS700 at frame rates up to 60p. The Odyssey7Q will auto-detect the incoming format and frame rate and capture it in its native format.
STATUS UPDATE -- FEBRUARY 27
Odyssey7Q February Firmware Status Update
(February 27, 2014, Colorado Springs) There are many improvements and added functions in our Odyssey7Q Firmware Update. Sony FS700 4K RAW recording, additional Canon C500 recording formats, and a host of small functions and minor fixes. The most anticipated new function is the popular compressed recording format to complement all of our other recording functions.
This codec is the intellectual property of another company, and Convergent Design needed to go through extensive technical training and then a certification process to make sure the code we wrote was qualified by the other company. We have been in continual contact with the other company and believe that we have answered all of the requirements it has posed to us. However, as of today, February 27, 2014, we have not been issued our certification.
Without this certification we are contractually bound from releasing this firmware. So while we fully anticipate full approval and certification from the other company, we must delay the release of our February Firmware Update.
Our engineers continue to work on. They sweep the code searching for programming bugs as well as work on additional functions that we have not yet announced. The firmware will improve every day.
It is not practical in the short term to release a version of the firmware update that does not include the popular compressed recording format. Its functions are intertwined with many others and locking it out could cause issues in other functions. However if the delay appears to extend beyond a minimal time we will do exactly this.
Again, we expect this delay to be very short-lived, and apologize to all of our Odyssey7Q owners for the delay.
New Features
- 1.33 Frame Guide.
- Screen flip.
- QHD up to 60p
- 4K RAW Recording
