Mitch Gross
With every new camera design there can be some initial growing pains. Convergent Design has been working with Antler Post's Nick Shaw to improve the workflow for RAW data files captured on the Odyssey7Q and Odyssey7Q+ from the Sony FS7. Nick has developed some LUTs that improve color performance and also written a detailed instructional primer to processing the files in Resolve. Please follow the link for details.
https://convergent-design.com/odyssey7q-knowledge-base.html?kbartid=28
With this workflow and LUTs, the magenta issue should be eliminated. The LUTs are for a Log image, and there is further instruction to then take the files into a REC709 gamma. Please consider these settings to be starting points, as you may wish to adjust them to your own taste.
These settings are for the FS7 camera only. It is for use with files recorded using Odyssey firmwares 2.10.100 - 4.10.100 (current). Future firmware may not yield the same results, and Sony's upcoming changes in firmware in the FS7 may also alter the image.
