Alan Ting Judson
Should i set my a7s Hdmi resolution setting to 1080p or 1080i?
Cause when i set my a7s to 25p and hdmi resolution setting 1080p, my 7Q+ will only get 50p the lowest no matter my project rate there set follow input or 25fps.
If i set my a7s to 25p and hdmi resolution setting to 1080i, my 7Q+ can record and display PSF25p
BUT
if i set my a7s to 50p and hdmi resolution setting to 1080i, my 7Q+ only will display PSF25p
If i set my a7s to 50p and hdmi resolution setting to 1080p, then no problem, it can record 50p.
So conclusion set to 1080i when want record 25p and set to 1080p when record 50p?
Another questions for 7Q+ and 7Q
1. what is the meaning of output overlays on odyssey 7Q/+
2. When i output from 7Q+ via SDI to 7Q, there is a green line/bar display on 7Q bottom, no way can remove it? Planning to record on both 7Q+ and 7Q as a backup but the green line/bar will be recorded into footage as well.
BUT
