any recommends on where to buy it Mitch? Who is getting a good amount of units that won't be sold out![]()
Great to hear Mitch. Any idea when you'll be shipping to your Australian/New Zealand resellers?
Dtap to Hirose would be useful out of the box.
You're right, I did read that. Probably best to get supplier to make up cable with Neutrik (particularly if they're tricky) connector to ensure I have power in case the cables from CD aren't available when units ship.Either of them would be fine. TBH, I thought it was a bit odd CD didn't just use a hirose connector on the monitor - it's a long established and reliable standard after all, rather than a non-standard connector from Neutrik. But, having spoken to Dan about it on another forum, as I understand it - they're making an Odyssey D-tap cable available, as well as a second cable, with O7Q on one end and flying (i.e. un coneccted) cables on the other (so you can wire the cable up yourself). But you'll need to buy one separate from the unit.
Apparently, the Neutrik connector can be tricky to wire (another reason would have thought hirose would have been a better option!) so it is not advised to build your own cables, unless you're a competent engineer.
Hi Mitch,
Thanks for the info! I've ordered the 7Q from Creative Video in the UK. I've asked about power options but they didn't have any information yet. Which type of power connector will the 7Q have?
On my steadicam I've got several power output options but would prefer to use d-tap to the connector you'll be using, will you offer such a cable? Since you say that it can accept 6.5-34V power, it would be great if there was a cable that could go from this battery to the 7Q, for a light weight configuration for handheld or shoulder mount where the 7Q is attached to the FS700. Another thing that would be great is if you had a hood of sorts, and a padded "sleeve" for the 7Q if you just want to put it in another bag.
I've noticed that the 7Q has threaded mounting holes on each side of the monitor. Will you provide any good mounting sollution for it that is much more solid than a noga arm?
Thank you!
