Is there anyway to select the format being output out of the SDI on the 7Q? When in the standard Prores (422 HD) the SDI outputs fine to our Marshall Orchid studio monitor, however when I switch over to 4K2HD Prores the Marshall monitor signal goes black. So, my question is, what exactly is being passed through the SDI and also, can I change the output to a format the Marshall will see?
BTW... as everyone has already said many times... thank you CD for finally allowing us to be able to shoot high contrast chromakey without any artifacting. After owning the camera for a year and a half, this piece of kit has finally made our FS700 what we wanted all along! I have posted on here many times about our high contrast artifacts and everyone always said- "let's see your lighting set up", or "you are doing this wrong"... heck even Sony replaced our FS700 because they couldn't figure it out. However, now when shooting 4K2HD not only is the image so much sharper, but that nasty white edge line on the right side of our chromakey images is finally GONE! We can finally use our 700 for GS work! Bout damn time.
End rant. Thanks for your help with the SDI question.
Ronnie
Ronnie
