Odyssey 7Q+ Not working with A7s???
skimmel
I just spoke with someone who said they had a 7Q+ and they cannot get it to read the signal from either an A7s or the GH4. Has anyone had any luck with this?
It works fine, you have to go through the menu system on the O7Q+ and pick "Sony" "Other" and a few other settings as well. Use the F5 LUT id you want to use a lut. And it will work great.
If you someone still can't make it work post here and I will post screen shots of the menu settings, but it is in the PDF manual. The O7Q has a very deep menu system because it does a lot, so it is a bit complex, I usually have to try a few times when I try a new camera until I get it right.
Maybe Mitch can chime in with more specifics...
They probably need a better HDMI cable or perhaps are trying to use multiple HDMI connector adapters. I don't have the cameras in front of me at the moment to go through the proper setup, but it can be a bit of a pain to navigate the menus, especially on the Sony. Once you have it done right it's quite easy, but if it doesn't work right on the GH4 either then I suspect the cabling.
Correct me if I'm wrong, but I've done a little bit of searching and I cannot find a Micro HDMI to Mini HDMI cable. So you have to have at least one adapter in the connection, right?
EDIT: Looking again on B&H and noticed that Atomos and Teradek are now selling short Micro HDMI to Mini HDMI cables for around $20-25. So there are a few out there, but doesn't look like anything longer than Atomos' coiled one that stretches to 17". Hopefully at least using one adapter is OK for if you're on a jib or something.
Using one adapter is fine with a good HDMI cable, which is why we include an adapter in the box.
Starting this week we will include a complete solution for HDMI mini to micro. I believe it is 3' long and thin enough to comfortably coil up excess on a rig.
For clients who have already purchased an Odyssey7Q+, contact us directly and we'll be happy to mail you one.
Hi all. Just wanted to follow-up. The problem was resolved with Convergent Design tech support. Turns out it was two issues: (1) cables/adapters -- a bunch didn't work and they finally found a combo that does work. (2) They had Info Display set to "on" in the toolbar section, 3rd menu.
Hope this helps others.
Haha, wow, since I owned the 7Q before the 7Q+ i didn't bother opening the white box (AC adapter) to find the HDMI adapter. Thanks for the heads up, Mitch.
