Odyssey 7Q general operating questions
Hi Everyone,
Loving the Odyssey7Q, I just had a few noob questions which I couldnt confirm from the manual. If anyone can help that would be great :)
1. Should you unmount the ssd's each time before you switch it off or is it fine to switch off if you leave the ssd's in the Odyssey7q?
2. Once you have finished recording a shot what is the best method to powerdown? eg: Do I switch off the FS700 first followed then by the Odyssey? Does it matter so long as your not recording?
3. When recording FS700 RAW, do I need to select a LUT on the Odyssey or does it factor it in automatically?
4. With recording audio, I noticed the RAW has a seperate audio file. Does this need to be synced seperately once editing? Does the 4k2hd file have audio combined with the video or is it too seperate?
5. In Davinci, when I select a 3DLUT the REC709 looks better than the S-LOG Lut, yet I used S-LOG setting on my FS700. Can I use the REC709 LUT?
6. Can anyone recommend a good sunhood?
Appreciate the responses, just starting to get my head around it all!
