Odyssey 7Q / FS700 SDI Issue
I was filming an interview with my Odyssey 7Q / FS700 combo and literally right before I was about to start the SDI signal cut out. Now no matter what cable I use, the Odyssey7Q says there is "no input detected."
Has anyone else experienced this? Going to try to find a way to run some troubleshooting tests, but thought I'd check here....
I assume you restarted both the O7Q and the 700. If not try that.
I have had the 700 sometimes semi crash. I have once had to reset the 700 to factory settings.
If you do they make sure you save any PP settings you have first or you will loose them.
Contact CD 24hr service # it is on the WEBsite, Dan will help you out.
Let us know what you find out.
