timmytimetravel
This might be important for Sony A7s, so thought I would tackle it now ahead of time.
1) The A7s outputs clean, full sensor read fullframe, recordable by the 7q and it looks damn good! Better than internal fs700 avchd, slightly less than 4k2hd. No moire or aliasing etc.
2) I cannot get 1080p 50/60 which is the fixed output of the camera to record correctly in the 7q.
I posted this query before, its now buried deep in the 130 page firmware thread. Also thought I would wait for the new fw with psf etc fixes to see if results were different. (i'm running the new fw).
I've almost got 50/60p from hdmi into the 7q using a hdmi>sdi converter. After trying 3 brands/models, the only one that worked was the atomos connect H2S (I've got battery version). It also does 2:2 pulldown, which lets me take a 1080i50 signal (which in many new camera is the only option aside from 1080p 50/60 fixed uncompressed out, and turn it into 25p which the odyessy can see in multistream for matching.
This was mitch's statement at the time :
"The Odyssey7Q cannot accept 1080p50 or 1080p60 over HDMI. It is a hardware limitation.
It can accept thaose signals via SDI, so you could purchase a small converter box, stick it to the back of the Odyssey7Q, power them off the same battery and record the signal that way. Note that at these framerates we currently only support DPX recording.
I can get 1080i50/60 into psf25/30. I can 2:2 pulldown 1080p50 into 1080p25. But I still cannot get a clean 1080p 50/60 signal into the 7q. I've two cameras tested, Sony A7 and fS700. Both have the same issue with 50/60p hdmi > sdi recording in the 7q in dpx.
Note the h2s has a very cool test pattern mode. I can set all sorts of framerates and test patterns. I found that once set to 1080p50/60 the 7q did have a harder time not detecting it as PSF. I swap into that mode, it shows psf. I leave the test pattern generating, unplug the sdi into the 7q, plug it in again, its detected as 1080p50.
Here are two examples. 25p and 50p. Converted in resolve but untouched otherwise. Also is some dpx original frames from the 50p.
Aside from mitch chiming in, has anyone seen these sort of wierd scanning effect before. Some crazy pulldown thing or ??
The wierd thing is, looks perfect on the screen during monitoring on the 7q, but the output looks as the example. Oh and the 25p has some wierd horizontal jaggies on it. Pretty sure I've just missed a setting, I'm sure I've got non interlaced looking footage out of it during a previous test. Maybe using pulldown instead of psf or vice versa.
https://vimeo.com/92037956
https://vimeo.com/92037957
DPX frame samples - https://www.dropbox.com/s/pg97tracs2yvznl/Archive 2.zip
Mitch Gross
Director of Communications
Convergent-Design
"Director of Communications
Convergent-Design
