O7Q playback issues still
Pgale
Anyone else having problems with playback still? When I select several clips and playback, part way into the playback the clip starts looping over about a second. Also corruption at the top of the screen and timecode corrupts with odd characters.
Also I get no timecode readout during playback at all :(
shame these basic issues aren't fixed.
Is it only when you select multiple clips? I usually only do one at a time and it seems to be working fine. Maybe multiple clips is messing it up?
Yeah I think it is multiple selections only. Do you have timecode display when playing back?
Doh! My mistake with the timecode thing - I just realised I was recording from the odyssey without the 700 recording, hence TC input was not running.
Mind you, this is maybe not what you would expect - if you have an input that has TC that's not running, you'd expect the recorder to run TC from that initial point? So the O7Q is recording a static TC.
I should set the TC input to seed/rec run when the trigger is set to rec button maybe.
Ah it looks like the issue and corruption with playback is when the recorded clips have static timecode. Looks like a bug, although whether the O7Q should actually record with no TC running is another matter.
