I've had a 50cm glidetrack for a year or so and I find it is often needing to be sprayed with silicone spray and occasionally given a knock with a rubber mallet on the bottom. Even then when I use it on a tripod (with a tripod plate screwed onto the bottom) I find it judders and sticks slightly in the middle. Its not touching/rubbing on the plate in any way so i can't work it out.
On the floor it seems ok but on the tripod it is a real pain.
I'm after something of similar length to replace this with and give this to my 2nd operator.
Would love some suggestions. Thanks
