Not so clean a chip
Colinelves
Hi there,
I've just had a client call up to say that the test footage they shot on my FS700 was really noisy - too noisy to use. I know that noise levels depends a lot on gain and so forth, but to be honest, looking back at my stuff, the biggest factor seems to be Picture Profiles.
I've tried shooting a couple of projects on different PPs designed to 'maximise the DR' of the camera. The AB-Range from Able cine and Noah Yuan-Vogel's FS700 Picture Profile. Both of which ended up producing images with a lot of noise in the blacks.
Strangely enough the Abel Cine NEX-Log seemed a lot cleaner. I'm just wondering if anyone else has any experience of this issue and if so could point me in the right direction to avoiding it.
Thanks,
Colin Elves
DP, Steadicam Operator,
London
www.colinelves.com
I think one of the 'secrets' of the FS700 is how much noise reduction the camera is doing internally. Comparing uncompressed output to AVCHD is quite different from the same comparison with the FS100, the 700 being quite a bit noisier. I've only really been able to see this in the field and i've not been able to do any quantative analysis and try and work out what's going on. I literally got the 700 a week before shooting and trusted it to be similar to the 100 in this regard. But it's not.
If you're doing anything that pushes the black levels up, with gamma settings then you're pushing that noise floor up too. The issue is where do you personally draw the line with the amount of noise being generated?
I really do want to pursue this as it will affect how the post pipeline works for me, so hopefully i'll have more to report soon
However in general i would agree, the 700 is noisier.
cheers
paul
That's sort of what I was thinking - it may be to do with the black levels in the two custom PPs I experimented with - although I would say the noise is very noticeable in the AVCHD footage as well.
I'm seeing a uniform noise pattern in the footage that looks like what broadcasters put over footage to make sure the Mpeg quantizers doesn't drop the bitrate too low in certain areas that aren't moving much. It's a cheap trick but it works.
The unfortunate part is that it makes it harder to color grade footage when your cB and cR channels aren't clean due to the bitrate being spent heavier in the Y picture than the other parts.
I've noticed this too but for some reason it's the kind of noise that doesn't bother me at all. It's not blocky, there's no compression artifacts and it's pleasing enough to my eye. I also gave it a shot and tried Neat Video on it. It completely took all the noise away. I was quite amazed how much of it I could clean up. But I also noticed that when compressing for web I got better results without Neat Video. For some reason compressing to mp4 with Neat Video on it creates a much more blocky, compressed looking image then it does if for the native footage. For DNxHD masters I will definitely consider using Neat Video if I need to push blacks up on certain scenes.
