Imaginate
I have audio recorded with an ME66 boom mic and the H4n. Its two people talking in a quiet room.
The levels recorded on the H4n tend to be quite low, I used a program called LEVELATOR to boost the levels and apply some compression, but I find the compression too extreme and I hear pumping...
I have access to soundtrackpro but haven't used it for treating my original h4n files... I'm curious as to settings some of you would use to process your audio files before the final mix.
I find normalization is a bit hit and miss if is one single peak in the waveform it will only the level as high as that one peak. I'm guessing a combination of subtle limiting and compression then normalization
yes no?
yes no?
