If I set the White Balance using the front button with a white card and then turn off the camera... will it remember that setting when I turn camera back on ?
Yes, and your reason for wanting it saved is quite valid. I run into this all the time....same set, long/multi-day shoot.
I guess its easy enough to set WB again... I shoot in manual mode... Reason I was asking is that the other day we were lighting a set before talent showed up and wanted to set exposure and WB but not leave the camera on for what might have been up to 30 min... assistant asked if the WB would be the same after turning camera back on... I had no idea ... Guess its always safer to re-check anywaysThanks
Is this specific to the DVX200? Not a noobie but I have probably bren guilty of doing that...turning cam off and back on and not re-whiting, especially in interview/all day setting. Many cams tell you the actual color temp theyre balanced to right next the display of what WB setting youre on (A/B/preset etc.)...I would think that would tell you if you're still balanced. Of course in an interview situation you're often constantly looking at a monitor so you would probably notice if the image looked off.
