jackal2513
Hi guys, I a thinking of adding a 101 to my kit. I shoot with a 5d but could use something with better ergonomics and workflow and the option to use af with the panasonic kit lens.
My questions are:
1. Is the quality of the af100 better than the 5d. i undestand that it has less aliasing etc. But is the overall quality and compression better. I find that the 5d can be a bit lacking when it comes to fine detail and pictures can look a bit mushy. If it isn't then what format does one have to jump to to get a significant increase in quality and bitrate ?
2. If the 100 has a 50% crop then presumably for a wide of say 24mm with the cverage or field of view of a 24mm lens, one would have to use a 12mm lens. Surely this would make for a very distorted image ?The last time i used 14mm lenses and the like the extreme perspective you get is all but useless for just about every application you care to mention.
My questions are:
