sean guerrero
i cant get any time code out to the firestore fs4pro hd 100, from my camera in hd mode.
we ran firewire out from a panny 900 and the device recorded in hd mode
note: the fs4 hd doesnt have some of the same settings as the older fs100s
note: i dont have a card in the p2 slot and i dont have a tape in the cage, from others running tapeless , theyve said you shouldnt need to have a card if your running direct into the hardrive when set to tapeless in p2 mode on camera setting.
running fcp6
camera settings: p2 1080i/60
other functions menu : 1394 control-ext
1394 command select rec p
pc mode 1394 device
recording setup tcg rec run
firestore settings record mode- normal
hdd mode- hd record
hd format- quicktime
setup- tc rec run
functions- fa tapeless
control- tapeless
when i switch to tape mode on the camera and to dv mode on firestore i get timecode
this has been driving me crazy and a lot of wasted time
any suggestions ? thanks
rogar-Kriz(DBG):
running fcp6
pc mode 1394 device
hdd mode- hd record
setup- tc rec run
control- tapeless
