No real 60fps on sony a6300?!
macgregor
I just found out an issue on the footage I shot on the a6300.
While reviewing some footage I shot at different framerates I discovered that the 1080p at 60fps does not have 60fps. Actually it does have 60fps but only one out of 3 is real, the rest are just the same frame repeated. I double checked this on AE, davicin and vegas.
This issue does not happen at 120fps.
Can anyone else try this at home asap?
I assume you were using 1/125th shutter? It's a long shot but my first thought might be when you switch to 60p it doesnt automatically correct your shutter, so maybe this is happening because you left your shutter slower than 1/60th?
Yep. I get that result when I forget to change my shutter speed (shoot 60fps with 1/50s shutter and half the frames are repeated). Maybe you found a bug that makes this happens in some situations even when the shutter speed is correct...
