pveal
CS6 user.
Good day to you, it appears that when you have merged clips you cannot subsequetly replace footage, this is ridiculous.
Desired workflow:
1. sync dual system audio with footage > merge clips > create synced/merged bin
2. Edit using these merged clips (native h264 files from camera) and going into audition to tweak the superior synced sound.
3. Finish edit then replace footage (h264 files) with up upconverted transcoded files
4. Import premiere project into after effects to grade / effect / conform / output
As I am unable to replace footage due to the merged clips limitation can any of you bright sparks recommend an alternative workflow? I would prefer not to transcode all footage first but perhaps this is the only option.
Surely this is a rudimentary requirement, being able to replace footage of synced clips? a shocking oversite or just bad bin mangement options?
thanks, i eagerly await a response.
Desired workflow:
