While at NAB, I learned about the Nnovia HD for HDV, which seems like a better product than the Firestore.
So I found their booth and spoke with the man there, turns out they are working in a HVX compatible model that will record 100gb onto removeable hard drives. Cost will be around 2k for the recorder +1 drive, and $400 for each additional drive (100gb). The drives are shock mounted and weather resistant. The best part is that the drive comes with a firewire/usb2 cable, so it would seem you could record 100gb, then swap the drives, and dump the footage to your computer while recording on the other drive. This makes much more sense than the firestore with the fixed 100gb size.
Finally, I asked to be sure it will capture the full DVCproHD 100mb stream, and he said it would. So I'm crossing my fingers.
BTW
I've been told that the Nnovia HD for HDV is pretty bombproof, one shooter said he's used it on many shoots including motocross riding and ATV jumping, all without a glitch. He also has used the MCE and Firestore models, but likes the Nnovia the most.
-Tomk
BTW
-Tomk
