GH2 Nikon to GH2 Mount
scotman
After to s of research I've decided to go with Nikon lenses for my GH2. Mainly because I already have a few primes (35,50 an 85) that I currently use for my Redrock Micro M2 adapter.
I want to get also an Rokinon 85 1.4 as well. I was wondering if someone could point me to a cheap but workable adapter to go from Nikon Mount To Gh2 MF3. Before I order I want to be sure order the right products and all interlinked
Thanks in advance
I bought mine from ciecio7, the Polish adapter seller for US$80. Holds the lens very securely and I like how the tripod adapter has two holes for extra stability.
Will these work with all Nikon lenses and rokinon( Nikon mount)? Thanks for the help guys
I'm in the same boat. The ebay ones look fine and well, but I want something with no play and is rock steady. I'm going to be using it only for an 80-200 2.8, and be hauling up mountain passes, so the stronger the better. Is the Novoflex that big of a difference over the cheaper ones? Since the 80-200 2.8 has an external aperture ring, is there a Nikon-4/3 adapter that is cheaper and doesn't have an aperture control ring?
OK. I just oredered this from AMazon can someone please confirm this will work on my GH2. I just want to be sure before they ship it. Thanksphoto.jpg
That looks good scotman except if you're planning on putting that UV filter on the Rokinon 85mm, you need a 72mm size filter, not 52mm (or a 52-72mm step-up ring which might vignette).
