This lens has only been used a few times and I have switched to Canon for video reason. It's 9/10 rating 10 being brand new . . I will not ship and its cash only
Thank you
The Tamron 200-500mm f/5-6.3 Di ultra telephoto zoom lens lets you bring your far away subjects up close while compressing the distance between the main subject and the background for professional-looking results. Even though it covers a range of up to 500mm, its design is relatively lightweight and compact. When mounted on an APS-C size digital SLR camera, it provides a focal length equivalent of 760mm for super ultra telephoto imaging.
The optical design of this lens enables you to get as close 8.2' (2.5 m) from your main subject at any focal length, and provides a maximum magnification ratio 1:5 at the 500mm end, allowing for dynamic and impressive pictures of small objects.
This lens sports the detachable Filter Effect Control ring. This allows a filter to be rotated to the desired position with the hood still attached, enabling you to simultaneously perform minute adjustments to a polarizer filter. You can confirm the Polarizing effect through the viewfinder, all while using the hood to prevent harmful light from entering the lens. Di (Digitally Integrated Design) is a designation Tamron puts on lenses featuring optical systems designed to meet the performance characteristics of digital SLR cameras. This lens does not have a built-in motor.
Note! AF not supported by D40 and D60, D3000 cameras.
LD Glass
Two LD glass elements reduce various aberrations while minimizing the fall-off of light at the corners
Internal Focus
The lens neither extends nor contracts physically when focusing; all moving elements are contained within the lens barrel
Di Design
Digitally Integrated design lenses are designed to meet the performance characteristics of digital SLR cameras
Tripod Collar
The tripod mount, detachable in one touch, is made of magnesium alloy that reconcile light-weight and high rigidity, resulting in enhanced balance and ease of use in hand-held shooting
Thank you
LD Glass
Internal Focus
Di Design
Tripod Collar
