[FS: General] Nikon High Speed Prime Lens Set (De-clicked, Matching fronts + Gear Rings)
andersonnd
Nikon Highspeed Prime Set
This great set of Nikon lenses has been de-clicked, so you have smooth aperture control all the way through like a true cine lens. If you haven't used de-clicked lenses before, they are something of a revelation – silent, full spectrum movement of the iris blades gives you a lot more freedom.
The glass is clear, no scratches or haze. All lenses have been upgraded to 80mm OD/77mm ID fronts for mattebox uniformity.
Front and rear caps included on all lenses. Also included on all lenses are 0.8 pitch Redrock gear rings.
The four lenses in this set are fast:
+24mm f2.0
+50mm f1.4
+85mm f2.0
+105mm f2.5
While I love these lenses, I am consolidating to PL mount lenses. Nikon mount shooters know these lenses are rare to come by. Also works great on my Canon with adapter (mine was ~$35 and does the job perfectly, eBay has tons of these).
A very similar set + 35mm f2.0 with pressed gears sells at RPLens.com for $3900+. This package is a screaming deal as I'm starting well under HALF PRICE.
Moved these to eBay
http://www.ebay.com/itm/251246841416?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
