eteam
To me that means PsF, and 24PsF would be 48i.
You should give Stephen a chance to confirm this assumption. If your assumption is incorrect (or uncertain), this will raise other questions.
-- Bob Elkind
This is what "Head Of Support" at Atomos wrote to me:
"We have been told of a lot of confusion about what the nikon actually outputs, is this what you are referring to?
When you look at the output options for the Nikon camera you only have 1080i or 720p, there is no option for 1080p output because the camera does not support it. Nikon output a progressive stream wrapped in 60i for computability.
We detect the 24P, 25P, 30P, or 50P 720 inside and then remove the 60i to leave a beautiful image form the original sensor.
The Ninja Firmware 2.1 does enable the Nikon images to captured."
Yes, but 3 weeks after you captured the video and you are rummaging through a source material library (with many contributors and video sources), how will CinemaTools know that reverse 2224 is the correct filter to apply, if any?I believe you can do 2224 pulldown removal with CinemaTools, but I'll have to double check.
Do you think with the Connect that the Samurai will be able work with the D4 changing HDMI to SDI?
Many of the low-cost HDMI recorders use lossy compression. So what started out as "duplicate" frames or fields may not end up as duplicate (100% match) frames or fields. Lossy compression can wipe out all the usual clues needed for reliable reversal of pulldown. Don't expect a NLE to guess between the various 24p to 60i pulldowns, plus 30p to 60i (2:2) pulldown.It's my understanding the 2:2:2:4 pulldown is the easiest pulldown to detect and remove since it's a single duplicate frame added instead of one field from one frame and one field from another frame like 3:2 and Panasonic's widely used 2:3:3:2 Pulldowns. I would think no matter how long ago the capture was it would be easy to detect with any modern NLE. Am I wrong?
None of the low-cost HDMI recorders use lossless compression. So what started out as "duplicate" frames or fields will almost certainly not end up as duplicate (100% match) frames or fields. Lossy compression can wipe out all the usual clues needed for reliable reversal of pulldown. Don't expect a NLE to guess between the various 24p to 60i pulldowns, plus 30p to 60i (2:2) pulldown.
I agree with Brian's answer to this question, and toss in another 2 bits.Do you think with the Connect that the Samurai will be able work with the D4 changing HDMI to SDI?
The Hyperdeck Shuttle and Hyperdeck Shuttle 2 can both record lossless HDMI. Both are under $350 for the recorder which make them the cheapest out there. I do agree it would be better for the recorder to do it tho.
If the HDMI => SDI converter is sufficiently capable, it will support the D4/D800 native HDMI signal formats. Then there is no need for pulldown or pulldown reversal.
Does this make sense?
-- Bob Elkind
Have just had an update from Atomos that they have released firmware 2.2 for the Ninja specific for the D800. It appears that it can now record the true progressive stream from the camera without wrapping it in an interlaced format.
