Isn't he missing the point rather? Any sensor larger than 4K can shoot 4k, given the rest of the infrastructure.
either that or the processor cant prcoess fast enough the huge amount of data which could lead to overheating OR could build a processor with insufficient codec capability aka mudNot at 24fps+. There is a reason most DSLRs lineskip and bin, their sensors simply can't run fast enough at full resolution. The sensor is actually the largest stumbling block of shooting high resolution at motion framerates.
high resolution, great. i would prefer to keep resolution at 2k and see increases in bit rate and dynamic range.
Well, I'm sure they'll increase the bitrate along with going 4k. Then you can scale down to 2k if you want and it will still look nice.
RE: dynamic range... again there should be a slight improvement as you are scaling down. Noise reduction software works better given a high-res signal - and that effectively increases both dynamic range and bit depth somewhat.
Also your bit depth improves a little too, since you are averaging 4 8-bit pixels. As long as there is some noise to prevent macroblocking in the compression, it should help quite a decent chunk.
Also, the mere act of scanning the full sensor without binning or line skipping should improve things too.
Bruce Allen
www.boacinema.com
