The latest version (64bit) of (free) 5DtoRGB for Windows can successfully use the new High Bit rate (I am ntsc) and transcode it to a progressive 4.2.2 Apple Pro Rez file. It looks great.
Format : ProRes
Format profile : LT
Codec ID : apcs
Duration : 25s 58ms
Bit rate mode : Variable
Bit rate : 134 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressive
Bits/(Pixel*Frame) : 2.160
Stream size : 401 MiB (99%)
Language : English
Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296M
Format : ProRes
Format profile : LT
Codec ID : apcs
Duration : 25s 58ms
Bit rate : 134 Mbps
Color space : YUV
Language : English
