I am the new owner of a DVX100a and I have several questions for those with more experience...
-Microphone- I bought an external microphone at best buy. The out of the mic is 1/4 phono plug but the dvx100a only has xlr connections, so I bought a converter at adio shack (from 1/4 phono to xlr female). Does anyone this is is bad or can ruin damage my camera?
-Hard-case= I bought a hard case for the camera and I have it s oeverything pretty much fits. My only worry is that I have to give it a slight tug to close it (granted, the case has foam molding that can form as time goes by) but I am still afraid that so much pressure can damage the camera. Did the same ting happen to your hard when you first bought it? was it a tight fit at first?
What are some recommended hard cases out there that people use? or am I just jumping the gun too quickly in thinking the camera doenst fit in the case I bought
-How can I manually export from a computer to the camera? If i put the camcorder on playback what do i press to record what I see on the vtr of the camcorder into the dv tape in the camcorder (in my last camcorder I had I would just press play and record)
Many Thanks to all,
Carlos
Many Thanks to all,
Carlos
