Newbie Questions
henryfinlay
Hi. I am an absolute newbie. I thought I knew what I was doing but this is a little more complicated than I thought. I own an HVX-200 and I have Final Cut Pro 7.
I do not know what people are referring to when they say 720/30p, 1080p, 1080i, etc. All I know is I just started shooting the stuff I needed to film, with whatever settings were on the camera. Now I have to learn Final Cut Pro, and the first thing that all these tutorial videos are telling me is that you have to put in all these settings so Final Cut Pro knows what it's working with. I had no idea, so when the 'Easy Setup' comes up, I just left it on whatever it was set as. (I'm guessing it's one of the DVCPROHD ones... but what about the numbers after: 720 or 1080? etc.)
I watched another tutorial that was saying to right click on the clips in the Browser and do Media Manager then recompress to Apple ProRes 422 something something something. Is this the same as the 'Easy Setup' or is this a different step?
I hope this gives an idea of where my knowledge stands. So now, what do I need to do to understand this stuff? How do I find out what settings I shot in? What do they even mean (720/30p, 1080/60p, etc)? Honestly, I think it's all the settings and Log/Transfer type stuff that I need to learn, and then I'll be good to learn the rest as I go. Thanks in advance.
EDIT: So I think I found out something important in my understanding. I looked at all my footage in the Browser and scrolled right to find all this Frame Size, Compressor, and Pixel Aspect stuff. All the footage is 1280x1080 HD, and the Compressor says DVCPRO HD 1080p30. However, the Easy Setup menu and the Media Manager menu don't have this '1280x1080' setting. What am I supposed to do?
Wow....where to begin.....did you buy your 200 new? If so, there is a lot of basic information in the books. Barry has books and videos as well that are loaded with extremely useful information.
Basically, the first number in your sequence is the width of your image in pixels, the second number is the frame-per-second rate, and the P stands for progressive. If you are not shooting P, then you are shooting i for interlace, which is native for SD and technically native for 1080. 720, meanwhile, is always P. With the 200, in 1080P, 30 is pretty much it for frame rate. If you switch to 720 (in your record menu) you'll have all kinds of choices.
Just as a fine artist uses different tools to achieve a particular look in a painting, so does a cinematographer use the myriads of options at his/her disposal to craft an image that best works for their particular story. The number of years it takes to learn the tools and the interactions between them is inversely proportional to the amount of talent you have (in my case it is taking a lot of years, believe me) and the best place to start is right here. Search this forum, and if all else fails, C&P terms you don't know into wikki, and then follow the links. Don't expect to get it right away....expect to read, read, and then read some more.
