I'm just starting to learn the hvx202E - the PAL version.
At this stage I'm shooting SD: 567i/25p to tape.
The manual says Vert Det Freq should be set to Thick when shooting 25p - it seems so as to avoid stair-stepping.
As the F5 default scene setting has Vert Det Freq set to Thick, and the F6 setting for Vert Det Freq is Thin, so does this mean that the F5 setting is intended as the basic default setting to use when shooting 567i/25p?
The manual only says that the F5 setting emphasises contrast while F6 emphasises dynamic range .. what does this actually mean?
