Danilo Del Tufo
Maybe at 100p (PAL) is available, or at least 50p.Not to my knowledge.
Thanks, instead at 200p and 100p (PAL) how many seconds you will be shoot before stops, and how the playback at 25p would be in seconds?
Is 180FPS continuous available also for FS5?
IIRC, it's a mount swap, and some models actually cover S35 (all but the wide angle ones?). Speaking from memory, though, and I had a pretty intense day today...
The FS5 cannot shoot continuous at 100p or 120p even in HD resolution. The limitation is due to the recording onto SD cards, which cannot reliably handle data rate faster. This cannot be "hacked" with faster cards, the architecture is designed around high frame rates going utilizing the buffer.
RAW will be another story. But that will come later when Sony announces future option details.
Thanks for the info Mitch, this is rather puzzling though - as my RX10 II can handle 1080p/120 continuous onto SD cards in XAVC-S just fine... strange world
What is the bitrate of the RX10's XAVC-S? I imagine its lower than the FS5's top internal recording setting which the cards would have to be qualified for.
I was able to ask a question to Alister Chapman via Facebook about waveform monitors on the FS5. Chapman was able to shoot with an FS5 recently. He said he did not see a waveform monitor option on the camera, but hpe did use a pre-production model. It does have a histogram.
Just to clarify some information that I posted yesterday on this thread. Initial reports said there was not a Waveform Monitor on the FS5 - which worried me a little as I use the WFM on my C100 and Ninja Blade a lot. Well, this hands-on article says the FS5 does have a WFM - thank goodness! It has some other interesting information/impressions about the camera too.
RedShark News - Sony FS5: First hands-on report
He has since posted that he has learned there is a WFM on the shipping product.
I contacted Alister directly and he said he did NOT make such a statement. He will try to check and see if there will be a WFM on the production models.
The Redshark review you linked to (not Alister's review) says they had one one their Pre-pro demo model, so we'll see which is correct.
