starcentral
Here's a graphical view of the data levels you get per stop with slog2 and slog3 when recording 10-bit:
Image taken from The Sony Ultimate Exposure Guide - cinetiny.com/exposeguide
With slog3 you do see more data is allocated to the mid and lower end which is taken from the highlights end of the scale.
It seems like a conundrum, but is it? Where would you rather have more data available for your image if its limited to 10-bit bit depth knowing it will need to go through post for de-logging & grading?
Here's something to consider. slog2/3 are 1300% dynamic range curves. It means that it can capture brightness values up to 14.5 times brighter than 90% white. That is pretty good, its about twice the amount of the original slog, and if you expose "properly" you will put about 200 levels of data to your top 2.5 stops above 90% with slog2 versus 275 levels of data for slog3. Is this difference really going to matter?
